Up to 20% off select tools
Mower does not mulch properly
Bought this late Aug. Two weeks before using. Home Depot basicly said not their problem. Has 3 days to do anything. Blade was dull. Does not mulch but blows grass and now leaves out right front onto top of mower which covers intake. Pushing just blows grass and leaves forward. I have to pull backwards to mulch, but it still blows forward and to the right. Tried calling Murray many times, but no one answers. It is useless and will eventually trash the motor since cuttings block upper vent. I must wear mask due to depree blowing up. I need answers! 309-846-0755 gregsstruve@comcast.net
2 Comments:
To comment on the answer. Blade was very dull, but sharpened before first start.
There is no opening up front. It just blows most of the dry grass and leaves out the right front bottom back onto the mower.
by Share
From the top of the engine, the blade should be turning clockwise, with grass clippings swirling until thrown into the bagger behind the mower. If used for mulching, is there a rear plug to prevent clippings from being bagged? Can the blade be mounted upside down, creating the problem of blowing clippings out from under the mower?
by Share
Add a comment
1 Answer
I asked FixBot (Ai) your question with its reply in italics. Be aware of Ai mistakes.
As shown, is the image below correct for your model lawn mower/mulcher? It's the mulch cover attached? Do you have two blades, one for mowing, the other for mulching? Are both new and sharp?
When a push lawn mower does not mulch properly, it is usually caused by wet grass, grass buildup under the deck, a dull or incorrect blade, or an unsealed mulch plug.
To restore proper mulching performance, check and address these common factors:
  1. Damp or Wet Grass: Wet clippings stick together and clump instead of circulating and being recut 1. Wait until the lawn is dry before mowing.
  2. Deck Buildup: Accumulated grass clippings underneath the cutting deck restrict airflow. Stop the engine, disconnect the spark plug wire for safety, and scrape away any caked-on grass residue.
  3. Blade Condition and Type: Standard high-lift blades or dull mulching blades tear grass rather than cutting it multiple times. Ensure you have a sharp mulching blade installed 2.
  4. Mulch Plug Alignment: Confirm that the mulch plug is properly fitted and inserted, and that the discharge door is fully closed so clippings cannot escape 2.
Mowing Pace and Height: Follow the one-third rule by not cutting too much grass height at once, and slow down your walking speed to give the blade adequate time to process the clippings 3.
2 Comments:
I have checked for obvious problems and everything is 'correct', except it doesn't work. I had my previous mulch mower for 26 years and it worked perfect. Underneath this new mower looks the same...but doesn't work the same.
by Share
@gregs39523 There may be several experts out there, familiar with small engine equipment. Perhaps reaching out to them after non support from Home Depot may help. One site may be https://chickanic.com/check-out-chickani.... A knowledgeable person is valuable in the internet community. As a casual diyer, I feel comfortable with a few online experts and chickanic is one of them. Another is an expert in auto repairs, South Main Auto.
by Share
Add a comment
Add your answer
Greg S will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 57
All Time: 57
