Up to 20% off select tools
Re pair guides, user and service manuals for The HP ProBook 650 G5. This technology is a computer technology to use for many purpose.
My laptop wifi problem
My laptop hp 6560 does not connect my wifi.
view wifi signal send signal is null
Add a comment
Well you can try the following:
  • Check the physical wireless button
  • Restart your router and laptop
  • Reset IP & Network Settings
  • Refresh the Wi-Fi Driver or update it & Power Settings
  • Test for Hardware Failure
  • Test with a mobile hotspot
Add a comment
check the wifi driver first. To do so
right click the start button
Open device manager.
Expand network adapters.
Look for a wireless adapter.
Check whether it has a yellow warning sign
Add a comment
The first thing you should do when your WiFi adapter (WiFi card) isn't working is power cycle your device.
While unplugged and powered on, hold down your power button until it turns back on.
Add a comment
Add your answer
Muhammad Asghar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 49
All Time: 49
