Computer blinking 3 time long 5 short
My computer suddenly shut off and wouldn't come on and the caps lock is blinking 3 long blinks and 5 short and the light is white.
@tiahanuman that blink code is fairly generic but commonly indicates that you are having issues with either the CPU or the motherboard. It is also possible that this is a BIOS issue. Try a hard reset first
Power off your laptop.
If that did not work you may have to attempt to recover your BIOS:
as always, you also want to check your RAM sticks. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
To work on your computer, use the guides from here HP 14-cf2112wm
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 46
All Time: 46
