Up to 20% off select tools
The first generation (2012 – 2017) Mazda CX-5 was the first model to fully incorporate Skyactiv Technology for better fuel efficiency and the sleek "Kodo" design language. It featured a 2.0L four-cylinder engine producing 155 hp, which offered an impressive 35 mpg on the highway.
I think dpf block
Hi just bought Mazda cx 5 2013 diesel when I drive on motorway it’s loose power stick 30 35 mph and missing but still drive what’s the main issue please explain thank you
Add a comment
1 Answer
Chosen Solution
@jagjeetsin59308 the symptoms you are describing, sudden power loss and restricting your speed to 30-35 mph, means your Mazda has entered "Limp Mode." The engine's computer does this intentionally to protect the engine from further damage when it detects a major fault. There are a few things that can cause this and it'll be a lot of guessing and a lot work and parts ($$$) on our side. Yes, it could be the DPF but it can also be caused by carbon buildup on the EGR valve as well as a worn camshaft etc. Start by scanning OBD2 Diagnostic Trouble Codes and let us know which code you get.
1 Comment:
Thank you oldturkey03
by Share
Add a comment
Add your answer
JAGJEET SINGH will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 55
All Time: 55
