Up to 20% off select tools
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
Storage change from tablet to tablet
I have a tab 2.7.0 which is smashed quite badly, even corners etc and won't turn on. I now have a 2nd hand one that works fine. I am wondering if I can change the harddrive with all my stuff stored on there, from the broken one to the newer one, as if nothing ever happened to the old one.
Add a comment
1 Answer
Most Helpful Answer
In many tablets and smartphones, the storage is provided by flash memory chips that are soldered directly onto the motherboard, instead of using a separate hard drive.
Replacing those flash memory chips is an extremely difficult repair, so replacing the entire motherboard is usually much easier.
If you can remove the motherboard from the damaged tablet and it has not been physically damaged, you might want to try swapping it into the replacement device.
iFixit has a motherboard replacement guide here:
Samsung Galaxy Tab 2 7.0 Motherboard Replacement
Score 1
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 48
All Time: 48
