Up to 20% off select tools
Was released in 2017, identified by model number CMCF810C1.
Trigger does not work
Trigger malfunction unit does not work
Add a comment
1 Answer
I asked FixBot (Ai) and its reply is in italics. Be aware of Ai mistakes.
If the trigger on your Craftsman CMCF810C1 impact driver is not working, check the following common causes:
  • Forward/Reverse Lock: Ensure the directional control lever located right above the trigger is pushed fully to the left (forward) or right (reverse). If the lever is in the center position, it locks the trigger for safety 1.
  • Battery Connection & Charge: Verify that the battery is fully charged and securely clicked into place. If possible, test the battery in another compatible V20 tool to rule out a dead battery or faulty connection.
  • Terminal Cleanliness: Inspect the metal terminals inside the battery housing and on the battery pack itself for dirt, debris, or corrosion that might be blocking electrical contact.
  • Faulty Trigger Switch: If the battery is charged and the directional lever is disengaged but the tool still shows no response, the internal variable-speed switch module may have failed and will typically require repair or replacement through an authorized Craftsman service center 2.
Sources:
1 CRAFTSMAN V20 Cordless Impact Driver Kit Instruction Manual
2 CRAFTSMAN V20 Cordless Impact Driver Manual
Add a comment
Add your answer
Tom Cronin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 45
All Time: 45
