Up to 20% off select tools
HP's 2018 Laptop/Notebook PC equipped with 8th gen intel processors and a 14inch display.
Blinking lights when power button is pressed
Charging lagane per white Patti ek bar bilink Karti Hai power button dabane per 5 bar pili batti karti hai
Translation Hindi - English
The white strip blinks once when charging is on. The yellow strip blinks 5 times when the power button is pressed.
Add a comment
1 Answer
Most Helpful Answer
@nitishyada44954 a single white blink on AC connection followed by 5 yellow/amber blinks when pressing the power button commonly means a critical power failure or motherboard fault is preventing your computer from booting, A shorted or completely dead internal battery can also prevent the laptop from booting even with the AC adapter plugged in.
  • Disconnect the AC charger.
  • Remove the screws on the bottom panel and carefully pry off the bottom cover.
  • Disconnect the main battery cable from the motherboard.
  • With the battery and charger disconnected, press and hold the power button for 30 seconds to drain all residual capacitance from the board.
  • Leave the main battery unplugged, connect the AC charger to the laptop, and press the power button.
If your computer now boots up normally on AC power, your battery has a failed and needs to be replaced. If it still blinks 5 times without the main battery connected, the BIOS may be locked.
  • Locate the small coin-cell CMOS battery on the motherboard If that still does not work, check the RAM..
  • Carefully unplug the CMOS battery connector from the motherboard.
  • Wait 5 minutes, plug the CMOS connector back in, reconnect the AC charger, and try to turn it on.
Your computer may turn itself on and off 2 or 3 times as it rebuilds the default BIOS settings. If it still blinks 5 times then you do want to make sure that your RAM is properly inserted. Remove the RAM and firmly re-insert it back into the slot, pressing down until the clips snap back into place. If you have two sticks of RAM try booting with only one stick.
If none of that worked you are most likely looking at a failed motherboard. You can try and see if schematics etc. are available for your motherboard. For that you will need to know the exact model of that motherboard. It will be printed on the board itself. Of course, you will need to know how to read schematics and have the tools and skills to perform a boardlevel repair.
To work on your computer use teh HP PROBOOK 440 G5 MAINTENANCE AND SERVICE MANUAL
Translation
@nitishyada44954 power button dabane par AC connection ke saath ek baar safed light ka blink hona aur uske baad 5 baar pili/embar light ka blink hona, aamtaur par kisi gambhir power failure ya motherboard ki kharabi ka sanket hai, jiski vajah se aapka computer boot nahin ho paa raha hai. agar laptop ki internal battery short ho gai hai ya puri tarah kharab ho gai hai, to AC adaptor lage hone ke bavjood bhi laptop boot nahin hoga.
  • AC charger ko disconnect karen.
  • niche ke panel par lage screw kholen aur savdhani se bottom cover ko hata den.
  • madarbord se men battery ke cable ko disconnect karen.
  • batri aur charger ko disconnect karne ke bad, power button ko 30 second tak dabakar rakhen, taki board mein bachi hui koi bhi electrical energy (capacitance) khatm ho jaye.
  • men battery ko disconnect hi rahane den, laptop mein AC charger lagayen aur power button dabaen.
agar ab aapka computer AC power par samanya roop se boot ho jata hai, to iska matlab hai ki aapki battery kharab ho gai hai aur use badalne ki jarurat hai. agar men battery na lagi hone par bhi light 5 baar blink karti hai, to ho sakta hai ki BIOS lock ho gaya ho.
  • madarbord par lagi chhoti coin-sel CMOS battery ko khojen. agar isse bhi kaam na bane, to RAM ko check karen.
  • madarbord se CMOS battery ke connector ko savdhani se nikalen.
  • 5 minute tak intjaar karen, phir CMOS connector ko wapas lagaen, AC charger ko connect karen aur laptop ko chalu karne ki koshish karen.
defolt BIOS settings ko phir se set karte samay, aapka computer apne aap 2 ya 3 baar chalu aur band ho sakta hai. agar iske baad bhi light 5 baar blink karti hai, to pakka karen ki RAM theek se lagi hai ya nahin. RAM ko nikalen aur use wapas slot mein majbuti se lagaen, jab tak ki clip apni jagah par wapas na aa jaen. agar aapke paas RAM ki do stick han, to keval ek stick lagakar boot karne ki koshish karen.
agar inmen se kuch bhi kaam nahin karta hai, to sambhav hai ki aapka motherboard kharab ho gaya hai. aap yah pata lagane ki koshish kar sakte hain ki kya aapke motherboard ke liye 'skimatics' (sarkit diagram) aadi uplabdh han. iske liye aapko motherboard ka sateek model pata hona chahiye, jo khud board par hi printed hoga. beshak, iske liye aapko skimatics padhna aana chahiye aur aapke paas bord-leval repair karne ke liye jaruri tools aur skills honi chahiye.
apne computer par kaam karne ke liye HP PROBOOK 440 G5 MAINTENANCE AND SERVICE MANUAL ka upyog karen.
Score 1
Add a comment
Add your answer
Nitish yadav will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 10
Past 30 Days: 42
All Time: 61
