11/20更新
その後、何か進展はありましたか?よくよく考えてみたのですが、以下のところが気になってきました。
>It takes quite a bit of pressure to screw the rear cap onto the Tube
ねじがダメージを受け締まり切らず、または少々腐食して接触が悪くて、ポイントCとポイントEの接触があまいのでは?と気が付きました。
機構や構造が面白そうだったので、似たタイプのCセル2本用の中古の動作するマグライトを仕入れてテストしてみました。
リヤキャップのねじ込みはかなりシビアで、3mmほど緩めると点灯しなくなりました。
※マスキングテープの位置と点灯状態をご確認ください。
動く実機が手元にありますので、抵抗値や電圧など調べたいことがあればお知らせください。
Update 11/20
Have there been any further developments since then?
After giving it some more thought, one thing in particular caught my attention:
"It takes quite a bit of pressure to screw the rear cap onto the tube."
This made me wonder whether the threads might be damaged and preventing the cap from fully tightening, or perhaps there is some corrosion causing poor electrical contact. In either case, the connection between points C and E may not be reliable.
The mechanism and construction seemed interesting, so I obtained a working used Maglite of a similar design (using two C cells) and ran a few tests.
I found that the rear cap engagement is quite critical. Loosening the cap by about 3 mm was enough to cause the light to stop working.
Please check the position of the masking tape and the illumination status shown in the photos.
Since I now have a working unit on hand, let me know if there are any measurements you would like me to take, such as resistance values, voltages, or anything else.
[ This message was translated with AI assistance. ]
Is the bulb showing continuity?
by honakrisi Share
@honakrisi
Continuity? Maybe I don't understand your question.
When the switch is at On, the bulb lights and stays lit.
by Mark578 Share
I suspect one of the following might be the case:
・The continuity state changes when the unit is assembled and pressed (between D and E, or at point A).
・There is a specific point where continuity between E and C degrades when the screw is tightened.
by mura mura Share
OK, I checked the Continuity of the bulb.
Yes, there is continuity between the two contacts on the bulb.
by Mark578 Share
Further confusion:
With a Universal Power Adapter, output set at 2.85 VDC (and the voltmeter confirms that), connected at A and B, it works.
when the Assembly and batteries are in (putting it all together),
so I thought that maybe there's too much pressure on A
(some broken connection Inside the Assembly?),
so I connected the Universal Power Adapter 2.85 VDC,
pushing Very Hard on A. It still works.
When the two batteries are lined up together, a voltmeter shows there is 2.94 VDC.
Add the Assembly (not inside the Tube) to that line, so A is touching battery #1 Plus, and a piece of wire from battery #2 Minus to B (in my 3rd picture): it does Not work.
I've tried using "Panasonic Super Heavy Duty C" batteries, and "Eveready Classic C" batteries; none will work.
My conclusion so far: this thing won't work, even using GOOD batteries.
But it does work with 2.85 VDC from another source. WHY?!
by Mark578 Share
Show 9 more comments
