Up to 20% off select tools
Slimline S5000 sold with Windows
upgrade old hp device
I would like to know what type of RAM and hard drive I need to upgrade my device
1 Comment
Hi
After doing some research , I found these two products. Could you please let me know if they are compatible with my device? for context, I`m not an expert in computer repair, So I just want to be sure about these two parts.
https://computerwinkelnissewaard.nl/128G...
https://computerwinkelnissewaard.nl/Voor...
Best regards.
by Share
Add a comment
1 Answer
Most Helpful Answer
@shortstory the HP Pavilion Slimline s5000 series typically uses a 3.5-inch SATA mechanical hard drive (HDD). You can of course also get a SATA SSD. It'll cost more but it'll speed things up a lot. This video shows you how to change it.
it uses DDR3 SDRAM (Unbuffered, non-ECC). PC3-8500 (DDR3-1066) or PC3-10600 (DDR3-1333) memory. Max is 8 GB and do no use one 8GB stick but use 2 x 4GB modules. Something like this (not an endorsement just an example) will work.
Score 1
Add a comment
Add your answer
Short Story will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 64
All Time: 64
