Up to 20% off select tools
Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in stereoscopic 3D on the top screen.
How to replace speakers?
How do I access and replace the speakers on the Nintendo 2DS XL?
Add a comment
1 Answer
There doesn't seem to be a dedicated speaker replacement guide for the New 2DS XL, but you can follow the initial steps in the iFixit teardown.
You'll need a Y00 screwdriver, a small Phillips screwdriver, and a plastic pry tool. After removing the back cover, be careful with the camera ribbon cable and its tiny locking connector. The speakers have small plugs and are held in place by screws, so you shouldn't need to solder if your replacement speakers come with the correct cables.
Before replacing them, test with headphones to make sure the issue is actually with the speakers and not the audio circuitry.
Add a comment
Add your answer
DAS Repair will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 53
All Time: 73
