Up to 20% off select tools
Turntable loss of power
My turntable has lately started to lose power at random. It happens both if it is playing a record or simply spinning idle: after few minutes, it simply goes off and for some time I cannot switch it on.
The plug and cable seem fine. Given it happens also spinning idle, I guess it is not related with the preamplifier or the connection to speakers.
Any suggestion?
Add a comment
1 Answer
Most Helpful Answer
@andreacass88610 sounds like something is overheating and then shutting down until its cooled off again. I'd start with the power supply.
As soon as the turntable shuts off, unplug the DC barrel jack. Measure the voltage on the DC jack with your multimeter (outside barrel is - and inside is +). It should show you 15V. If the voltage has dropped below that then your wall adapter is getting too hot and failing under load.
If the power supply is working properly, then the problem is on the internal motor control board. One of the components (the voltage regulator, PTC thermistor, or a failing capacitor) is failing as it gets hot. Remove the bottom cover of the turntable and run it until it shuts down. You can narrow it down by using some electronic freeze spray on each of the components. See if cooling a component instantly restores power to the turntable.
Let us know what you find.
Score 1
1 Comment:
Thanks. The DC barrel jack is fine, and I got some help inspecting the board. No success, but we did not have freeze spray. Not sure it is worth keep investigating. I wonder if I can find some spare board.
by Share
Add a comment
Add your answer
Andrea Cassioli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 30
