Phone fell into water
Phone fell into water and does not turn on but when plugging it on charger it vibrates
@terrencemalu720 for now you wnat to stop plugging it in. Applying power to a wet circuit can cause further damage. The vibration indicates your main power rail is active and the charging circuit is functioning. Sounds like either your display circuit is shorted out or the screen itself is dead.
The very first step you want to take is to disassemble your phone. Since iFixit does not yet have a guide for this phone, use something like [this video. Remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
I personally do no longer clean the charging boards, but I replace those. They are fairly inexpensive and readily available at many places. By replacing it I always have a known-well starting point should further troubleshooting become necessary.
Take a careful look at all components and connectors. Look for major corrosion, evaluate the pins in the connectors etc., Take a look at all connectors as well as cable ends. . Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
In your case it does sound like you have a display issue so you do want to consider replacing the display. If you still have trouble with the display after that then the issue is most likely on your main board. For that you will need the schematic, the board layout as well as have the tools and skills to perform a boardlevel repair.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 38
