Up to 20% off select tools
This laptop is designed to help users with their everyday tasks by using the latest technology available at the time of its release in 2013.
no voltege in screen
Dell [3521] - No voltage on LVDS connector - JLVDS pin 1 is 0.29V only
Update (10/15/26)
1 Comment:
Hello, more details about my board:
Board: Dell Inspiron 15-3521
Problem:
- Fan spins when power on but no display (black screen)
- No voltage on JLVDS connector, Pin 1 = 0.29V only, should be 3.3V
What I did:
- Found shorted MOSFET, removed it, short gone
- DX1 had corrosion, I cleaned it
- Checked 000 resistor near UX1: it beeps but 0V on both sides
- Checked UX1 (6 pin IC near JLVDS): 2 pins = 1.9V, other 4 pins = 0V
- No continuity between UX1 and DX1
- JLVDS connector not getting 3.3V
I have motherboard photos, I will upload them.
What should I check next? Is Q2309 the one that supplies 3.3V to LVDS?
Thanks for help.
by Share
Add a comment
1 Answer
Hi @rifaataboyasr
Black screen could either be a not passing POST (power on self test) problem, a faulty screen backlight circuit problem a faulty screen or a motherboard problem.
You haven't said what you tested to isolate what the problem is but try some of the following checks:
Reassemble the laptop and then turn on the laptop and connect an external monitor to the laptop's HDMI port and check if there's a display seen on it. Don't forget to press the F8 (or Fn + F8) keys to switch the display from the laptop screen to the external monitor.
If there is a display seen on the external monitor then there's a problem with the laptop screen.
Switch the display back from the external monitor to the laptop screen and try shining a flashlight at an angle close to the screen and check if you can see any images on the screen. They will be very faint if they are there so trying this in a darkened room may help.
If you see images on the screen, then it's a backlight problem.
If there are no images seen on the screen, then it's a screen or motherboard problem
If there is no display seen on the external monitor then the laptop may not be passing POST, there's a screen problem or a motherboard problem.
Little steps maybe but at least you're narrowing it down.
Note:
If the motherboard is a Compal LA-9104P then pin 1 on the LVDS connector is a data lane and the voltage is usually 0.2V - 2.2V
If you mean that the LCD panel is not getting any voltage to operate then check pins 24 & 25 (+LCDVDD), pin 26 (+3VS) and the backlight power supply on pins 39 & 40 (+INV_PWR_SRC)
See p.21 of the Dell Inspiron 15 3521 Compal LA 9104P Rev 1.0 Schematics
Add a comment
Add your answer
rifaat aboyasr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 61
