Up to 20% off select tools
The OP-1 field is the improved synthesizer from teenage engineering following their OP-1.
OP-1 Keyboard replacement availability
When will the OP-1 keyboard be availble? It has been out of stock for a while now and I need one as I have an important button that doesnt work and I need a replacement keyboard.
1 Comment:
I am not asking about a whole keyboard but the sparepart you sell for the OP-1. When will your sparepart be available?
by Share
Add a comment
here is a used one = https://reverb.com/p/teenage-engineering...?
Add a comment
Unfortunately, TE doesn't seem to have any replacement keyboards available, even if you contact them directly, so I wouldn't expect iFixit to restock them either.
As alternatives, you could try a community-made DIY keyboard replacement called Choccy Mod (you can find it on Etsy), or modify the firmware to remap the broken key to another key.
Add a comment
Add your answer
Viktor Steinarsson will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 116
All Time: 179
