Up to 20% off select tools
The Craftsman Gas Snow Thrower 536.881800 is a gasoline-powered device designed to remove snow from driveways, sidewalks, and parking areas. This page provides detailed information and repair guidelines for this snow thrower that comes in different engine displacement models (148 cc, 206 cc, 305 cc, and 342 cc).
Engine rpm excessive when using
Engine rpm fluctuates or is not controllable.
Add a comment
1 Answer
If the RPM is running away or fluctuating badly, I’d stop running it until you find the cause. A small engine overspeeding can do some serious damage. On these snow blowers, I’d check the governor linkage and spring first. Make sure the linkage moves freely and hasn’t come loose, bent, or been installed in the wrong hole. Also check that the throttle plate isn’t sticking.
After that, look for a vacuum/air leak around the carburetor and intake. A lean condition can make the engine surge.
Don’t try to control the RPM by manually bending the governor arm. If you can post a picture of the carburetor/governor linkage, we can see if something is out of place.
Add a comment
Add your answer
Gary Howard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 62
