Up to 20% off select tools
front loader mildew smell
my front loader washing machine has a bad oder. I've cleaned the front filter checked the soap dispenser and the cleaned the rubber seal. I leave my door open after use and do a cleaning cycle regularly. despite my upkeep and maintenance the washing machine has suddenly developed a mildew oder. I believe I need to take it apart but need to know how.
Add a comment
1 Answer
Before taking the machine apart, I’d check the less obvious places again, especially the drain pump area and the folds behind the rubber seal. Those areas can hold moisture and residue even when the visible parts look clean. If the smell still remains, the exact model number would help determine what can safely be removed for a deeper clean.
Add a comment
Add your answer
Annalise Porto will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 68
