The Nissan D-series produced from 1986.5–1997 represents a long-running lineage of compact and mid-size pickups. Mostly recognized by the D21 "Hardbody" and the subsequent D22 Frontier. Introduced in the mid-1980s to replace the Datsun 720, the D21 featured the first V6 engine offered in a small Nissan truck in the U.S.
Windshield wiper not moving
Driver side Windshield wiper no longer moves after wiper replacement, appears to be exterior connection
Add a comment
1 Answer
On an old D21, if the passenger wiper still moves but the driver side doesn’t, I’d look at the wiper arm connection first. The arm sits on a splined shaft and is held by a nut under the little cap. A loose nut or stripped splines can make the motor work while that arm just sits there.
Since it happened right after replacing the blade, I’d also make sure the blade itself isn’t binding on anything. Turn the wipers on and watch the arm connection. If the shaft is moving but the arm isn’t, you’ve found the problem.
Add a comment
Add your answer
Patricia Benka will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 25
