Up to 20% off select tools
Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a four-door sedan.
How to fix sunroof?
Sunroof wont open or close.
Add a comment
1 Answer
Most Helpful Answer
Hi @charlestully
Is there any kind of noise coming from the sunroof when it's trying to be opened or closed?
Just trying to ascertain whether it is an electrical problem or a mechanical one.
If there's no noise at all this could indicate that the sunroof motor is not getting any power to operate.
Check if the 20A fuse #3 in the interior fuse panel is OK and not blown.
If the fuse is OK (or even if it has blown and replaced and it still doesn't work) here's the wiring diagram that may help.
Let us know what you find?
Score 1
Add a comment
Add your answer
Charles Tully will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 72
