Up to 20% off select tools
The Toro 22in Recycler Lawn Mower with SmartStow® model 20340 is a self-propelled gas lawn mower with a bagger.
Mower will not start
Gas is coming out of the air breather with white smoke out of the exhaust. Hard to pull the cord for a couple of times then it rotates once.
Add a comment
1 Answer
Sounds like the carburetor float valve is stuck open most common due to old or dirt in gas
Drain gas tank and clean the tank
Clean the carburetor
Remove the sparke plug the crank the mower a few times to remove any gas on the piston
Dry and clean the sparke plug then reinstall
Clean the air filter
Change engine oil cause there will likely be gas in the oil due to flooding
Add a comment
Add your answer
Robert Mount will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 33
All Time: 89
