Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
How to fix my laptop
Charging or won't turn on
2 Comments:
What is your exact model? Apple has produced quite a few! Look at this listing to find what you have and tell us. EveryMac
by
It's a model A1278
by
Add a comment
1 Answer
Given the systems age you likely need a new battery. Here's the needed part with the tools if you need them MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and here's the guide MacBook Pro 13" Unibody Mid 2009 Battery Replacement
Do deck the chargers MagSafe plug LED lights up if not fully clean the grey socket area and the contacts using isopropyl alcohol and cotton swab.
Do tell us if the LED IS NOT LIGHTING.
Replace a 5800 mAh battery compatible with MacBook Pro 13" Unibody (Mid 2009 to Mid 2012). 63.5 Watt Hours (Wh), 10.95 Volts (V). Image
Product
$69.99
Add a comment
Add your answer
Justin Barnes will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 47
Past 30 Days: 47
All Time: 47
