The Realme Note 50 is an entry-level phone released in January 2024. The phone features a 6.7" IPS display and a side-mounted fingerprint reader. This model aims to strike a balance between performance and affordability.
How to place new lcd
Steps to set new lcd
Add a comment
1 Answer
To replace the LCD screen on a Realme Note 50 (model RMX3834), power off the phone, heat and remove the back cover, disconnect the battery, and carefully separate the damaged display assembly before installing the new one. [1]
Tools Needed
  • Replacement LCD screen (with or without frame)
  • Heat gun or hairdryer
  • Plastic pry tools and opening picks
  • Small Phillips screwdriver
  • Suction cup
  • B-7000 or T-7000 repair adhesive (if using a screen without a frame) [1, 2, 3, 4, 5]
Step-by-Step Replacement Guide
1. Disassemble the Phone
  • Turn off your Realme Note 50 completely.
  • Apply heat evenly along the edges of the back cover using a heat gun or hairdryer to soften the adhesive.
  • Use a suction cup to lift a small gap in the back cover, then insert a plastic pry tool to carefully release the clips all the way around the frame.
  • Remove the screws holding the upper motherboard shield/cover using your Phillips screwdriver, then disconnect the cover. [1, 2, 3, 4]
2. Disconnect the Battery
  • Unplug the battery connector from the motherboard immediately to prevent any short-circuits during the repair. [1]
3. Remove the Broken Screen
  • Disconnect the display flex cable running from the bottom or side board to the main board.
  • Apply heat to the front edges of the broken LCD screen to loosen its adhesive.
  • Gently pry around the edges of the display to separate it from the middle housing frame. If your replacement part does not include a frame, clean off all old adhesive and glass shards from the phone's inner frame thoroughly. [1, 2]
4. Test the New LCD
  • Connect the flex cable of the new replacement screen to the motherboard and temporarily plug in the battery.
  • Turn on the phone to test touch sensitivity, color accuracy, and backlight functionality before applying any permanent glue.
  • Turn the phone back off and disconnect the battery and screen again after a successful test. [1]
5. Install and Reassemble
  • Apply a thin, even layer of fresh adhesive (like B-7000) along the clean frame edges if you are installing a screen without a pre-attached frame. [1]
  • Lay the new LCD screen carefully into place, routing the flex cable correctly.
  • Reconnect the display cable and secure the battery connector back onto the motherboard. [1]
  • Screw the protective shields back into place, snap the back cover down firmly, and use rubber bands or clamps for 1–2 hours to let the new adhesive cure properly.
Add a comment
Add your answer
Archiel Guayan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 44
All Time: 42
