Up to 20% off select tools
The Meta Quest 3 mixed reality headset was released on October 10th, 2023 and is the direct successor to the Meta Quest 2 and in many ways the spiritual successor to the Meta Quest Pro.
Update and restart loop
I have bought this device used, so I have no warranty.
The device keeps updating and restarting, side load update didn't work because the site said incompatible device or something like that, and factory reset didn't work either (it reseted and still had the loop).
Is there some different manual way to fix that, maybe somehow completely wiping the quest 3's SSD and manually installing the OS?
Add a comment
1 Answer
Most Helpful Answer
Hi!
It sound like firmware/NAND issues.
It would be very difficult to fix this.
I would check with Meta their support to see what options you have.
Anyway, if you would like to know more about it's NAND, you can follow this: Meta Quest 3 Chip ID
Hopefully Meta does have a solution for you or maybe you can sent it in, so that they can refurb it.
Sorry for the bad news.
Score 1
Add a comment
Add your answer
Aleksandr Muchin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 90
