The Dell Latitude Series is designed mainly for professional use. This model is a 14" laptop released by Dell in 2018. The Dell Latitude 5490 emphasizes durability, portability, security, and is known for its long-life cycle.
Weird boot device not found error.
I'm losing my mind here and would highly appreciate any proper help.
My problem is obvious from the title. A temporary solution i have is to just take out the ssd and put it back in at which point it works perfectly for a couple or few days before freezing where the only way out is a restart through the power button where I'm met with the same error again. How do I fix this problem permanently?
Reinstall my OS (I use Linux Mint)?
Changing the UEFI option in the boot menu and back didn't do anything.
Maybe it's a problem with the motherboard?
Add a comment
1 Answer
Hi @johndoe23811
When the error occurs, if you restart the laptop and get in BIOS on startup, does the SSD information i.e. make and model number, appear in BIOS > System Information > Device information?
If it does this may indicate that the boot partition in the SSD is corrupted.
Perhaps check if the RTC coin cell battery voltage is OK.
Here's the owner manual for the laptop. Go to p.19 to view the procedure to remove the coin cell battery from the motherboard.
Regarding the main battery, you don't have to remove it, just disconnect the battery cable from the motherboard.
When the coin cell battery is out, if it is <2.4V DC or if the battery is >4-5 years old, replace it. Search online for C8KT2 to find suppliers that suit you best.
Before reconnecting the coin cell battery (either original or replacement) press and hold the laptop's Power button operated for a full 30 seconds and then release it.
Then reinsert and connect the coin cell battery, reconnect the main battery, close the laptop, connect the charger and check if it turns on and boots OK.
If it does there may be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset back to factory default by the above. Once the date and time have been corrected, the message won't appear the next time the laptop is turned on.
Also any user definable BIOS settings that were changed by you to suit whatever system requirements you had, will need to be changed back again also.
Add a comment
Add your answer
John Doe will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 8
Past 30 Days: 8
All Time: 8
