The Honda Fit, also marketed as the Honda Jazz, is a five-door, front-engine, front-wheel drive B-segment subcompact car manufactured and marketed by Honda since 2001 and now in its third generation. Marketed worldwide and manufactured at ten plants in eight countries, sales reached almost 5 million by mid-2013.
Drop rpm when ac is on
Add a comment
1 Answer
@delosohomer you are not providing enough information for a definite solution. We would need to know what exact year and engine size your Fit is. Also, let us know how far down the RPM's drop.
Common issues with the smaller engines are related to a dirty Throttle Body, an ECU that requires a idle relearn procedure as well as a bad AC compressor that might be failing and causing a drag on the engine. Start with those things and give us the details about your Fit so we can try and help you with that.
Add a comment
Add your answer
Deloso Homer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 42
All Time: 42
