Porque no carga rapido
No carga y no sale de 1
Translation Spanish - English
Because it doesn't charge quickly. It doesn't charge and it doesn't exit from 1.
Add a comment
1 Answer
@luismiguel23018 you are not telling us if it charges at all. You are also not saying if the fast charging ever worked on this phone. It is most liklely that your K22 does not support fast charging or that you may have a bad charger and/or bad battery. Use the original charger that came with the phone an see if that will work. Let us know what you find out.
Translation
@luismiguel23018, no nos estás diciendo si se carga o no. Tampoco nos dices si la carga rápida ha funcionado alguna vez en este móvil. Lo más probable es que tu K22 no admita la carga rápida o que tengas un cargador defectuoso y/o una batería estropeada. Usa el cargador original que venía con el móvil y comprueba si así funciona. Cuéntanos qué tal te va.
Add a comment
Add your answer
Luis Miguel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 34
