Logitech G Pro Wireless battery connector extremely stuck
Trying to replace the battery on a Logitech G Pro Wireless (Guide 145490, Step 15), but the battery connector is completely stuck. Tweezers slip, prying risks breaking the socket, and looping dental floss under the wires isn't possible due to tight clearance. How can this stubborn connector be safely removed without damaging the motherboard?
My guess is plastics stick together after time passes. Perhaps some gentle heat/freeze cycle(s) with some penetrating fluid may loosen plastic connector bonding. Try a tiny bit of WD-40 between plastics, carefully prying each side of the battery male connector inside its female socket. This may break any bonding occurring since factory assembly. Once disconnection occurs, clean everything with isopropyl alcohol with a cotton swab (Q-tip).
by F Dryer
