Repair, disassembly, and troubleshooting information for the 4th-generation AirPods, Apple's entry-level wireless headphones. Launched September 20th, 2024 with two available models, with and without ANC. Identified by model numbers A3058 and A3059.
Right bard is not charjing
Right airport is not charging
Add a comment
1 Answer
Hi!
Are you getting any other symptoms such as flashing lights, or anything?
Start of by cleaning the AirPods and their charging case, specifically the charging pads/connectors on the earbuds and inside the case. You can follow Apple's Official AirPods cleaning guide.
If cleaning them does not work, try resetting the AirPods. You can do this by:
  • Put the AirPods in their case.
  • Close the lid.
  • Wait 30 seconds.
  • Open the lid, then double-tap the front of the case three times.
Please respond whether this helped or not, or if you have further questions.
Good luck.
Cheers.
Add a comment
Add your answer
Akash Gill will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 88
All Time: 106
