Why is the car not starting?
I gave it a new battery and it sounds like it wants to start, but it doesn’t?
2 Comments:
Year, mileage, maintenance performed? Presuming your description is the engine cranks but doesn't fire up can mean; fuel pump/pressure, intermittent spark, serious engine mechanical issues, blown head gasket, worn out spark plugs, factory anti theft system enabled without any indication, etc. Making armchair quarterback guesses are easy with little background info.
by
Hello, based on your description, I highly suspect the crankshaft sensor, but without any Diagnostic report, I can only give you some hacks to try if you want to.
by
Add a comment
