How to check and replace the battery if neededm
Hp 15s-fq5012nx
Hi
Yesterday the laptop was at 95% and in almost a minute the charge dropped to 10, recharging only brings it into 14 or so, which is definitely not a great sign, so i want to check on the battery to see if it's a fire hazard (spicy pillow) that need a replace
(Was using fedora-atomic-based linux at that time if that's helpful)
Add a comment
Most Helpful Answer
Hi @darandomcube
Here a guide that shows how to check the battery's health using Linux.
If the battery needs replacing, here's the maintenance and service guide for the laptop series. Go to p.30 (38 of 88 pdf),to view the procedure to remove/replace the battery in the laptop.
Depending on your location, (as ifixit does not ship batteries outside the contiguous USA), search online for L11119-855 to find suppliers that suit you best.
Score 2
Add a comment
Hello,
You can check if the battery is a spicy pillow without opening up the laptop! Just look for an unusual bulge in the bottom or the trackpad bulging upwards. Otherwise, here is the part:
HP HT03XL Battery
T
Replace a 3630 mAh battery compatible with HP HT03XL. Image
Product
HP HT03XL Battery
$59.99
Score 1
Add a comment
Add your answer
TheCube will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 21
All Time: 21
