F15 error code showing on panel after cycles stops
The error code F15 shows on the panel and beeping intermittently and the cycles stops. This doesn't happen all the time, and at various times in the cyles. Checked obvious, water inlet, drainage filter etc
5 Comments:
Hi @Tom what's your model number?
by
The model number is
WFC 3C33 PF X
by
It’s a powerclean 6th sense
by
@tom19692
Have you checked that the dishwasher's drain hose is clear and not kinked or clogged.
Also check that the drain pipe to which the hose is inserted or connected is draining away OK
by
To add to that, try repeatedly starting a cycle and then cancelling by holding the START/PAUSE button, and listen for the drain pump to run. Drain pumps can fail intermittently, and if so eventually you may hear a soft hum instead of the pump running
by
Add a comment
