Beeps no display can call help me
All it does is 4 beeps all it does
1 Comment:
@caseyteska36918 4 Beeps is usually related to a bad power supply. Open the case and make sure that the 4 or 6-wire power supply cable is seated into the connector on the system board.
Check if a device is causing the problem by removing ALL attached devices (such as hard, diskette, or optical drives, and expansion cards). Power on the system. If the system enters the POST, then power off and replace one device at a time and repeat this procedure until failure occurs. Replace the device that is causing the failure. Continue adding devices one at a time to ensure all devices are functioning properly.
by
Add a comment
