Two broken Side ventilation area
Hello, I accidentally cracked two of the plastic fins on the upper left side cooling vent of my PS4 Pro while cleaning it. The top cover still clips back in very securely and doesn't move. I already cleaned the fan and inner vents from dust. Will these broken outer fins cause any cooling issues or let in too much extra dust? Please check the attached picture. Thank you
4 Comments:
We can't see the pic...
Adding images to an existing question
Try this then we'll be able to help you
by Share
@leooooo1061 I apologize for the mistake; I didn't notice. It's alright, I checked and everything is fine with the device. However, I have a question: should I buy an 850V 420W UPS without connecting the monitor, and how long can the UPS handle (I only need at least a minute) to ensure the PS4 Pro is protected? Thank you.
by Share
@hmdaaly59969 nah it's OK, if it's working fine then that's great. Unfortunately I don't really know a lot about UPSs so I'm afraid I can't help you here
by Share
That UPS will hold. The PS4 Pro should take 200watt under load monitor maybe max 60 watt. So yes, it should hold it for at least 1 second :)
by Share
Add a comment
