Repair and disassembly information for Google's Pixel 7 smartphone, released in October 2022. Identified by model number GVU6C and GQML3.
Dead device a week after battery replacement.
I used an iFixit kit and followed a guide here about a week ago to replace a poorly performing battery. After buttoning it up everything worked fine. I ran a calibration cycle and had multiple days of normal use. Suddenly today I pulled it out of my pocket around noon (probably had about 50% estimated charge) and it was unresponsive and cold to the touch. Here's what I know:
  • If I put it on a wireless charger the wireless charger blinks enough for me to assume that the battery is attempting to negotiate with it
  • If I use a known good 65w charger (UGREEN) and multiple high quality USB-C cables, I can get it to show a gray battery on screen with a lightning bolt in it, but after multiple hours it doesn't seem to produce a charge. The phone is slightly warm near the charging port. If I take it off the port it 'dies' (loses the little battery indicator) instantly
  • If I try and put it into fastboot nothing happens, except that the battery indicator will sometimes go away, so maybe it's discharging faster than it's charging?
  • If I hook it up to my Linux machine with dmesg running, it doesn't seem to be negotiating anything over USB :(
I like to think I'm generally pretty competent when it comes to working with electronic components. The only thing out of the ordinary with the battery swap was having to use 99% IPA to dissolve the battery adhesive, but I was conservative and it was completely dry before reassembly. I'm skeptical about the battery just being disconnected given the nature of the connector, but I'm open to cracking it back open if it comes to it. The bigger issue is that it leaves me phoneless for quite a while which is rough for 2FA.
Thanks
Score 1
Add a comment
1 Answer
Chosen Solution
This sounds like a classic case of a defective battery. I'm not an expert in Google Pixel repairs, but if this were my phone, I would start by reaching out to iFixit Customer Service and initiating an RMA.
Score 2
1 Comment:
Yup. I cracked the phone back open to see if it somehow needed reseating and got to see some magic smoke on my second test. With the old battery, it works "perfectly" (as well as it did before the swap). RMA was accepted. Thanks!
by
Add a comment
Add your answer
Clinton P will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 67
All Time: 67
