The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
iPhone isnt recognised and doesnt boot
iphone charges and holds charge, however it doesnt boot and after 1 minute a spinning wheel appears in middle of screen. mac, ubuntu or windows 10 doesnt recognize it in normal mode, recovery mode and DFU. i was already tried to clean the 30 pin connector with isoprophyl alcohol but nothing helped. i tried two apple 30 pin cables and same thing.
Add a comment
1 Answer
Hello,
So here is the bad news, the phones storage drive most likely is corrupted, likely to the point of bricking the device. You could try to fix it, but you would have to have extreme skills in order to replace the storage drive is corrupted. Otherwise, you could try to use some sort of app or website to resurrect it, but that would be risky.
Best of luck,
T
Add a comment
Add your answer
Pavol ‎ will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 35
