The Lenovo Yoga 7 14ITL5 is a 14-inch 2-in-1 convertible laptop featuring a Full HD touchscreen, Intel’s 11th-Gen i5 or i7 CPUs (with integrated Iris Xe graphics), up to 16 GB RAM and 1 TB SSD, and a 71 Wh battery in an aluminum chassis.
How to fix screen detaching from frame at hinge?
The LCD screen on my Yoga 7 14ITL5 has come away from the backing panel at the left-hand hinge and the laptop won't close. How do I fix this?
Add a comment
1 Answer
Most Helpful Answer
Hi @johnhubbar64560
Here's the hardware maintenance manual for the laptop.
Go to p.45 (51 of 84 pdf) in the manual to view the procedure to remove the LCD unit.
At the bottom of p.46 → p.52 1 (52 → 58 of 84 pdf) it shows how to disassemble the LCD unit so that you can check if the hinge screws in the lid are tight etc.
Score 1
Add a comment
Add your answer
John Hubbard will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 66
All Time: 161
