Oneside earphone is not working
Ticon wx-470 one side of earphone is not working but another side of earphone is working so how to repair it explain me
Hi!
This is likely due to a broken cable.
You will have to locate the damage, and then replace the broken piece. This however can be hard on those style of earphones.
To locate the malfunctioning part, you'll need to look for any damage, wear, or tears. It will likely be at:
Once you've located the problem area, you will need to cut off the damaged cable, and the replace the damage part with a new cable. (Note, there will be two tiny cable inside one lead.) This will require soldering.
If the damage is by the base of the cable to the earphones, you may need to open the end compartments. Look for seams and try to wedge something small to open them, e.g. a guitar pick, and hope that it isn't glued down. Caution, forcefully opening the end compartments comes with the risk of damaging them.
It is possible to repair these headphones, but it will be challenging.
If you have further questions or want further clarifications, feels free to come back and ask more.
For further diagnosing, you may update your question with images, and/or upload some images of how you repaired them to help other people with the same problem.
Good luck,
Cheers
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 25
All Time: 49
