Up to 20% off select tools
This unit cools or heats the water it circulates through the ChiliPad mattress pad. Model: CP-CUBE
NO Power comnpletely dead
Chilicube has no power. Completely dead. Thermal cutout switch appears not to have tripped as i have tried resetting. Any ideas Thanks.
Add a comment
1 Answer
Chosen Solution
Hi @andrewlovell
Disconnect the power to the device and use a DMM's (digital multimeter) Ohmmeter function to check if the line input fuse F1 has been blown.
Here's a composite image taken from Step.9 of the ifixit ChiliTechnology ChiliCube Teardown guide showing where the fuse is located.
If it has blown unfortunately I can't zoom in close enough on the image to read the specifications that are printed on the fuse case. You may have better luck. If you go to order a replacement get 2 or 3 as fuses generally don't fail of their own accord. If the replacement fuse also fails then the reason for this will have to be found.
(click on image)
Score 2
2 Comments:
Thanks for the info. I will let you know how i progress.
by Share
Fuse is good. So still looking.
by Share
Add a comment
Add your answer
Andrew Lovell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 139
