Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
replaced battery. apple icon flashing
Replaced battery with ifixit but apple icon flashing
Score 1
Add a comment
1 Answer
A flashing Apple logo after a battery replacement usually means the phone isn't completing the boot process. It could be caused by a faulty battery, a connector that's not fully seated, a damaged flex cable, or another hardware issue that occurred during the repair.
I'd start by reopening the phone and carefully checking all the connectors, especially the battery and display.
If you're able to retrieve any logs, run an iPhone panic log analysis. I'd also run a battery metrics analysis to verify that the replacement battery is communicating correctly with the phone. These checks can help determine whether the issue is the battery itself or something else.
Add a comment
Add your answer
James Dixon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 22
