Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
Why is my network signal lost?
The Iphone fell on the ground and some minutes later the network signal was lost. When you flash it, the network signal re-appears but it's lost shortly
Add a comment
1 Answer
Hi Michael, When you dropped your iPhone you most likely knocked a connector loose or at worst cracked the soldier joints on the motherboard.
Let's try a few things.
In Settings > General > About, does "Modem Firmware" show a version, or is it blank?
Blank usually indicates a baseband communication problem.
Present means the baseband is at least communicating with iOS.
Dial *#06#*.
  • If the IMEI is missing, the issue is likely with the baseband.
  • If the IMEI appears normally, the fault may be in the RF or an antenna was knocked loose.
The IMEI missing means that your baseband has gone bad and will require expensive board level repair.
At that point, it is better to replace the device then waste money fixing a 7 year old, out of support iPhone.
I recommend a 13 base model or 14 base model as both will get iOS 27 and are still supported by Apple.
Let me know if you have any questions.
Happy iFixing.
Add a comment
Add your answer
Michael Kyei will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 18
