A 15.6in laptop with an identified by model number: BoB-Wai9
No Boot Device After Turning On the Secure Boot
Huawei MateBook D 15
I tried to enable Secure Boot.I got the error No Boot Device, I can only go into windows when I disable it. But I need the Secure Boot enabled so I can play Valorant.
When the Secure boot is enabled Bios does see the SSD
Is it a problem with the Windows UEFI do I need to format the PC.
Güncelle (07/21/26)
It does show the asterisk. But I dont have the Bios setting for CSM/Legacy support does not exist in BIOS. I tried to reset the BIOS, nothing changed What should I do?
Add a comment
1 Answer
Hello, it could be a couple of things I can think of, to help find out the cause, boot into Windows with Secure Boot off, open a command window cmd ctrl-shift-enter or just open admin cmd,
type:
diskpart , hit enter
type:
lis dis , hit enter (short for list disk)
check the output, find your disk - in the GPT column for your drive is there an asterisk? If not, then that is why. You would need to investigate mbr2gpt conversion, which can be... a little more tricky, or not!
If your disk is GPT format already, then the culprit could be in BIOS settings, look for Legacy/CSM Support type options, usually they are off when Secure Boot is turned on, but it really depends on the BIOS... (search up your motherboard and BIOS version + secure boot may help?)
1 Comment:
by
Add a comment
Add your answer
Eren Günaydın will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 24
Past 30 Days: 24
All Time: 24
