Repair guides and support for weed whackers, also known as string trimmers, weed eaters, edge trimmers or line trimmers.
Can I string weed eater with zip ties
Add a comment
1 Answer
Most Helpful Answer
My guess is no because zip ties are flat when plastic strings are round. Round strings flung out from its anchoring point at spinning speed tends to straighten out as it cuts vegetation. Zip ties are flat and may become ineffective as the flatness acts against air to move it up or down with the edge not cutting vegetation. There's also a balance issue if zip ties are attached incorrectly. Centrifugal force can create an imbalance resulting in vibration that may be unmanageable. If grossly attached incorrectly, the hub may suffer damage from vibration, an unbalanced string trimmer..
Score 2
Add a comment
Add your answer
Cheryl Simmons will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 34
All Time: 45
