Screen Backlight suddenly went off
I observed that my screen backlight start blinking and suddenly went off. What is the cause and possible solutions.
Well I will suggest you to restarting your laptop if if didn't work then try ti rest the display driver.
A blinking backlight that suddenly goes off usually indicates a failing LCD backlight, loose display cable, faulty inverter/LED driver, or power issue. Test with an external monitor to determine if the graphics card is working. If the external display works normally, the laptop screen or its backlight assembly likely needs repair or replacement.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 86
