Up to 20% off select tools
The Xiaomi Redmi 9C is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G35.
How to replace mobile screen
Add a comment
1 Answer
Most Helpful Answer
It's fairly straight-forward on your phone, much the same as it is for a lot of Android phones. First thing is to take off the back panel, then unscrew the midframe retaining plates on the top and bottom. Disconnect the battery first, then the display connector from the motherboard and the lower connector on the daughter card. Separate the LCD from the midframe and remove it. Clean the old adhesive, glue on a new display with something like B7000 and reassemble. This video shows you the whole process.
Redmi 9c Lcd Screen Replacement Without Frame - YouTube
As you work, take lots of pictures and once you're done, you can use them to create your own iFixit guide to that repair. It's easy, fun, and will have the appreciation of the repair community, especially those who come after you with the same problem.
Create a new Guide - iFixit
Good luck, and let us know how it all turns out!
Score 1
Add a comment
Add your answer
Tiwana Tiwana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 83
