How to fix my ethernet port?
My ps fell while plugged with ethernet cable and now the port is a little bit mor inside the console than it should be and a bit loose
Hi!
Does the port still work??
If it is loose, then you might need to open it up and check the network port. Maybe you need to solder it to the pads again.
We can't tell for sure, unless we see pictures.
Please let us know if you need any guide or whatsoever.
Thanks!
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 44
