How to repair electrical socket plugs
How do I repair plugs when I insert an extension lead it doesn’t work
Different countries have different wiring standards and how power is fused. So I can't tell you where to look as there are quite a few possibilities. You may want to get a local electrician in as he is equipped to deal with most of the possibilities.
Keep in mind you can get hurt if you make a mistake!
I would look for the breaker/fuse panel and locate the breaker/fuse for the outlet to see if it's still good. If not you may have a short in the line.
@humphreygxowa what country do you live in? Let's see what the wiring standards are wherever you live. What have you already checked and what have you already tried?
South Africa
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 90
