Up to 20% off select tools
Looking for Replacement Battery
Hello Community,
I’m looking for a replacement battery for my HP Spectre, which I believe is the 15-inch model. At the moment, the laptop still works fine without a battery because the old one is no longer working.
Unfortunately, the battery is not available in the I fix it store, so I wanted to ask whether anyone could recommend a trustworthy seller where I could purchase a replacement battery.
Please find attached a picture of the original battery that came with the HP Spectre.
Thank you in advance for your help! Bet whishes, Franziska Klenk
1 Comment
One small thing I noticed – I just saw the picture in the upper right corner of the Spectre x360 and I am a little confused, as I am not able to rotate the monitor like shown in the picture. So I am wondering if it might be a different model?
Thanks again! 😊
Best regards,
Franziska
by Share
Add a comment
1 Answer
Chosen Solution
Hi @franziskaklenk
Your laptop model is HP Spectre X360 15-df1711ng.
Here's the maintenance and service guide for the Spectre X360 15 series laptops that will help you to replace the battery.
Go to p.31 (39 of 93 pdf) in the guide to view the procedure to remove/replace the battery.
Search online for L29184-005 to find suppliers that suit you best.
The battery model number i.e. SU06XL or HP part number i.e L29184-005 is usually printed somewhere on the battery.
ifixit discourages giving recommendations as it leads to an increase in spam being posted on the site.
If you find a supplier before purchasing the battery, check what warranty is being offered by them and their returns policy.
For example if they claim that the battery is an OEM (original equipment manufacturer) then the warranty should be 12 months. If there's no mention of this then it's usually 3 months. Do they accepts returns if the battery is faulty within their warranty period yes/no? etc.
Also search online for reviews regarding the supplier as to the whether they are worth dealing with or not based on what other people buying from them have posted online. Then use your instinct to decide if they're suitable or not for you.
Moderator.
Update (07/12/26)
@franziskaklenk
Do you mean being able to fold the laptop like a tent as shown in the image of the laptop in the top right of this page?
When opening the laptop you should be able to push the lid past 90° through 180° (so it lies flat) and then right on through to 360°.
If you can't move it past 90° don't force it!
It could be a problem with the hinges.
Check the hinges for ant debris etc which may be restricting their movement. Use a can of compressed air if you think that there is something there.
Also check their alignment. For example one hinge may be moving but the other one isn't. This could be due to loose hinges screws or hinge mounts. See p.39 inthe maintenance guide to see how to check the hinge screws.
The laptop model number (HP Spectre X360 15-df1711ng) that I posted is shown in the image that you posted in your question
(click on image)
Score 2
2 Comments:
Hi,
thank you so much for your detailed and helpful response! I really appreciate the time you took to provide all this information, especially the tips on finding a reliable supplier and what to look out for when purchasing a replacement battery. This will definitely make the process much easier for me.
Thanks again! 😊
Best regards,
Franziska
by Share
Thanks again! 😊
Best regards,
Franziska
by Share
Add a comment
Add your answer
Franziska Klenk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 36
All Time: 189
