L2 triggers right stick
When I press L2, it triggers my right stick up, and even after I release it it still moves up.
Hi!
So, the issue is either with the stick, button circuit membrane OR a trace on the motherboard.
Testing will not be easy, I always test with new parts to identify.
First I’ll start with the easy parts. Please open it up and clean the button membrane circuit, also where it connects to on the motherboard and test again. Also clean the joysticks.
If the issue is still there, replace the button membrane circuit.
Guide: DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement
If that fails, replace the right joystick and try again (you do need to solder and have soldering experience).
Guide: DualShock 4 Right Analog Stick Replacement
If that fails as well, it’s most likely related to the motherboard and you need to check the traces.
Please let us know how it goes!
Guide
Difficulty:
Difficult
30 minutes - 1 hour
Guide
Difficulty:
Moderate
1 - 2 hours
how do i clean it exactly, like do i just use a cotton swab or something
Hi!
You need isopropyl alcohol and a cloth. Clean it completely and see how that goes :)!
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 106
