Thin 1 pixel Intermittent Horizontal Line on Screen
We have 2 A1502 units here (2013 & 2015) that both have a tiny 1 pixel vertical lines on the display, it is sometimes there at boot, then they go away, and sometimes appears after a period of time (On both units). (2013 1 line) (2015 4 lines at equal distance apart). The lines do appear to show at the same point each time. We have cleaned the connections and all appears super clean. Is this a sign of a faulty LCD or something else. The next step I guess would be to swap out the LVDS cables as we haven't as yet tested that way. Testing with other displays & externally there is no issue at all, displays tested on other units and the issue persists so it is 100% something in the assembly, so each display likely is suffering the same or very similar problem. We have reset SMC / PRAM to. no avail and both units are using a clean installed stock SSD. Or is there something simple I may have missed? Or are we facing early signs of a failing T-Con or LCD?
