The Malibu was redesigned for the 2008 seventh generation. This generation of Malibu came in many trim levels: the Base (2008 only) (1SB), the LS 1LS (or 1FL for fleet models 2011 and 2012), the LT 1LT (or 2FL for fleet models 2011 and 2012), the Hybrid (2008 and 2009 only), and the LTZ 1LZ. Only the top-level LTZ trim package was fitted with clear brake light lenses with red LED lights, the balance of trim packages retaining red lenses with conventional brake light bulbs.
Door panel is jammed
I got T-boned! How do I repair the door panel?
Add a comment
1 Answer
Most Helpful Answer
Hi @hollywoodsucks
It's probably easier to replace the door.
Here's the Front Side Door Replacement procedure from the service manual that may help.
Search online for Malibu front door to find supplier.
I used 2010 as the model year as it should be the same for the vehicles in the year range you selected but maybe insert the model year of your vehicle.
Score 1
Add a comment
Add your answer
Hollywood Sucks will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 12
All Time: 54
