Plus d alimentation No power
Plus d alimentation
Translation French - English
No power
1 Comment:
@follicalai30783 what exact model is your microwave? What have you already checked and what have you already tried to fix it?
Translate
@follicalai30783, c'est quoi exactement le modèle de ton micro-ondes ? Qu'est-ce que tu as déjà vérifié et qu'est-ce que tu as déjà essayé pour le réparer ?
by
Add a comment
1 Answer
Microwaves are dangerous. Proceed with troubleshooting or repair only if you're able and willing to follow safe servicing practices.
Most microwaves have a line fuse that disables all power to the microwave. The most common cause of a blown fuse are failed door switches, or sometimes uneven wear on the bracket that holds the door switches from the prongs on the door. For replacement door switches, I prefer to order from an electronics supplier, like DigiKey (I'm in the states), bear in mind the connection terminals are commonly either 4.7mm or 6.3mm, shop accordingly based on the switches used in your unit. Though the number of terminals on the 3 or 4 door switches will vary, all can be replaced with 3-terminal (SPDT) switches. Example 6.3mm tab switches linked below:
https://www.digikey.com/en/products/deta...
Add a comment
Add your answer
Follic Alain 879052 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 61
